Problem with hypertext link
I'm using Filemaker pro 5 unlimited. Whenever I try to use CDML
<a href="FMPro?-db=databasename&-format=filename.htm&.........>
to access a page, I will hit runtime error. The error message is 'Attempt to load 'Access URL: http:// ........' failed. No object data.
Anybody knows what's the cause of this error? Urgent.
  • 1 month later...
I am not familiar with FMP5. However I am with 4.x.
You have set web companion up correctly, but have you gone into each database file itself and activated web companion in its sharing options?
Does the database have records in it?
