March 3, 200719 yr Newbies Hi All, I've created a stand alone database app for use on a windows machine. I have a button marked "print to pdf" with that command assigned. When I use that function inside filemaker it works great. When I compile it to a stand alone app the button quits working. I'm using a similar button to "print to excel" that works both within Filemaker and as a stand alone app. Does anyone have thoughts on why I'm having the "print to PDF" issue when compiling the database as a stand alone app ? Any advice is sincerely appreciated... Regards, Terry
March 3, 200719 yr "Save Records As PDF" is not supported in Runtimes. It is a licensing issue. See Here
