extend found sets without losing position
hi all,
i'm sure this has been covered before but i can't find a way to extend a found set without losing the original record I found.
Let's say I search for
recordID=255
which pulls up the correct record immediately. I then want to extend the found set to include
location=Overseas
However, this effectively makes me go to another record than 255.
I've also tried
1. search for recordID - 255
2. show all records (this keeps the desired position)
3. omit records where location not=Overseas
The only way i can think of doing this atm is to loop through all the records again until i get to the one i want, but it seems that there must be a much simpler/more efficient way.
Basically, I want to replicate the "go to related record" script step without using a portal
Since you have marked you profile with advanced, would a posible solution be to enter a CF in a Go To Record statement:
Sift(target;found;theField) = Case(target = GetNthRecord ( theField ; found );found;Sift(target;found-1;theField))
So yes it's basicly a looping, but hopefully a little faster than scripted looping???
BTW when and where is such funtionality really required?
Untitled.zip
That is a cool Custom Function. But in this case couldn't you also use a global to capture a unique value, then use Go To Related Record to go to it? Just don't check "Show only related". I don't know which would be faster.
Sift_GoToRecord.zip
Indeed, it just escaped me in the moment - it must be faster! Although globalizing everything to your hearts desires - not is fully embraced as programming habit ...at least in other tools than filemaker:
A global variable therefore has an unlimited potential for creating mutual dependencies, and adding mutual dependencies increases complexity
http://en.wikipedia.org/wiki/Global_variable
thanks to both of you, both solutions work fine. I'll probably use fenton's purely because I may be able to use that global field for other things as well.
To answer your original question, what this is for is to create a previous/next record button, but to have the button actually display the record title of the previous/next records. Previously I'd been using a set of relationships to work this out, but a problem arises when two records share the same title, also this method will allow for customised sorts.
Danger! It was exactly the point quoted from wiki... a collectors bad habit in thinking something might come in handy later - localize and narrow the scope, or sit for hours to document dependencies!
