A script for using field values from other files?
Hallo,
I am looking for a way to create a script, with which I can insert a field value from another file automatically.
By pressing a button in File B, the serial key from File A should be insert automatically into File B.
Is there a way.
Ralf from Uganda
This is opposing relational mechanics I'm afraid! You make the other files field accessible by referencing a keyvalue by which the link i made, only when a present state of a fluctating value needs documented are lookups justified ...so the key to it is linking on key values!
Also answered here:
http://filemakertoday.com/com/showthread.php?t=12753
