Problems with setting Find criteria
How can I Find records that have a blank in the Committee Action field? The only values for the field are either Admitted or Rejected. Records for which no action has yet been taken are blank. I've tried =" ", ="", = . I wasn't able to do it on a layout either.
For another report I want to list applications received since the last review date, which the user would input when running the script. The script I've written runs correctly, but I want to limit it to those with a File Started Date greater than a date from the user.
Thanks bunches!!!
In a script the = must be in quotes for a text field like so.
Set Error Capture [on]
Allow User Abort [off]
Show All Records
Enter Find Mode []
Set Field [YourField; "="]
Perform Find []
If ( Get(LastError)= "401")
    Show Custom Dialogue ["NRF";"No Record Found."]
End If
The same would hold true for the set field step to insert a date criteria, like so.
Set Field [YourDate; GetAsText("> "&EnteredDate)]
HTH,
Tim
