export as xml file : header problem cause using ""
Hello again.
I'dd like to export a field value in an xml file.
I'dd thought I'dd do it using a calculation field witch contains the raw xml layout.
The problem is, in order that xml is valid and readable is neads a header line like this :P
<?xml version="1.0" encoding="ISO-8859-1" standalone="yes" ?>
the "" are my problem how to keep them as is.
example : normally I do this ...
"<?xml version="&"1.0"&" encoding="&"ISO-8859-1"&" standalone="&"yes"&" ?>"&..... etc...
But this get's rid of my needed "" at 1.0 ??
How to resolve this ?
Kind regards
