second page print problem
This is my first official post. I was redirected here from Fm tech support.
Here is my situation:
I am using FMV6.0, Epson LQ-590 Impact Printer, WinXPPro.
Here at the office we are required to print these government certificates on an impact printer. These certificates are numbered, preprinted and a bizarre size. Now I am able to print the first page no problem. The problem starts with the line of the second page, it starts too low. All these certificates are on one continuous roll, and we are suppossed to print them out multiples at a time and tear off once done.
In print setup, I change the page from "Letter" to "C5" and it does line up a little closer, but still not properly. In "C5", I would need to move the bottom of the first page lower about an inch.
Thanks in advance,
Heeter
It sounds like you're going to have to set up a custom paper size. This is a function of the printer driver, not FMP itself.
Have you tried palying around with header and footer sizes on the layout, see if that helps?
Thank you for the response, Vaughan.
I have played with the header/footer sizes on the layout, dragging them up/down around the page.
I first contacted Epson before I came here. They said that the second page problem is the setup in the software, not their printer setup.
Now I am confused.
Heeter
