ODBC Problems with OS X 10.3.9 and FMS 9 Advanced?
I was wondering if anyone knew if this problem has been fixed before I update my server. I'm running OS X 10.3.9 and FMS 8.02 Advanced on my xServe. I had problems with my ODBC connections when I upgraded to FMS 8.04 (check the link below). I'm just wondering if anyone knew if this problem was fixed in FMS 9. I really don't want to upgrade only to have to reinstall 8 if it doesn't work.
Problem with FMS 8.04 Advanced & OS X 10.3.9
The minimum required Mac OS for FileMaker 9 is 10.4.8.
When updating your server to 8.0v4 did you update your Web Publishing Engine to 8.0v4 as well?
Yup. I updated everything.
Well, I guess there's no problem then. : Time to buy more software!
