Attached is a simple sample of a script Trigger done entirly in Filemaker. I threw this together using FM9 on vista and I do not know how it will behave on any other platform. (Limited useful
(Limited usefullness but still "Kind of Cool")
: I forgot somthing, If you use this in a solution the Global fields used to trigger the scriptd should be omitted from the tab order so the only way to enter them is by clicking them.
TriggerFind.zip
