Anybody with Vista experiencing this or knew of a solution please HELP. Whenever I switch to layout mode; Filemaker seems to hand (For less than a Second not like XP forever) and then Vista force
Whenever I switch to layout mode; Filemaker seems to hand (For less than a Second not like XP forever) and then Vista forces it to close... no way or work around it. It i
Now It started with some files, but its like a virus that has spread to EVERY filemaker file...Even the ones that are downloaded from their website... The same files open on My XP machines, with no problem... I have decided to Downgrade my tablet to XP if no solution found.
This is the only program in Vista that behaves like this; I mean other programs hang, but usually the system might waite for a program to respond> But with FM9, Vista does not let it breath, it just forces it to stop. In my research this seems to be an issue that could be relating to the application memory management.
I tried to uninstall/reinstall several times and under different directories... no luck!
Here is what the "Event Viewer" Shows.
Log Name: Application
Source: Application Error
Date: 9/11/2007 7:15:54 PM
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: ********
Description:
Faulting application FileMaker Pro Advanced.exe, version 9.0.1.63, time stamp 0x4678929d, faulting module FileMaker Pro Advanced.exe, version 9.0.1.63, time stamp 0x4678929d, exception code 0xc0000005, fault offset 0x0028ac16, process id 0x18b4, application start time 0x01c7f4c8755d2680.
Event Xml:
1000
2
100
0x80000000000000
9430
Application
9.0.1.63
4678929d
9.0.1.63
4678929d
c0000005
0028ac16
18b4
01c7f4c8755d2680
