TO's and Relationships FMP's way of SQL?
Just curious if FMP is simplifying (graphically) the concept of SQL Queries using TO's and Relationship graphs?
For example -
If I have 2 tables in a database - Customers and Invoices,
Would creating a TO based on Customers be the equivalent of saying in SQL
SELECT * FROM Customers
And making a connection between Customers and Invoices in Relationship graph would be the equivalent of the rest of the SQL statements like
SELECT * FROM CustomersTable, InvoicesTable
WHERE CustomersTable.CustID = InvoicesTable.CustID
AND
CustomersTable.DateOfCreation ≥ "1/2/2006"
If you use ESS then the tables are essentially "brought in" to the FileMaker solution, and you can use them as FileMaker table occurances - FM will take care of all queries on your behalf.
Right, misread the question, the answer is yes, but you do not have access to anything but that graphical representation.
Note that the queries are also taken care of when you perform search's etc.
Sh..orry Im Sho drunk.
Shpank You.
riiiiighhhhtt...
