SQL Login problem
I am new to SQL setups - however, I was successful in opening my SQL database on a seperate server from my FMSA, however, only by using a standalone version of FileMaker. When I attempt to get into it from a shared file via FMSA I am faced with a "login" screen. I have tried avery possible login and I am not sure what "login" it is looking for. Again, If I access this same database from a standalone version of FileMaker on the same machine as the FMSA, I can get in without any additional login. I do have the DSN set up as "system". Any suggestions/help would be appreciated!
