Import/Export Problem
:) I have a solution consisting of two files. The main file has 25 tables. The primary table in the main file deletes all records in itself and imports records from an external db nightly. Several other tables do the same thing. I can no longer delete the records in the primary table either through the script or manually. It gets almost done and then FileMaker forces all users off, closes the file and shows that none of the records have been deleted. This is done with a Full Access account. Is it possible for a single table to be corrupted? If so, can you recover a table w/o recovering the entire file?
  • 3 weeks later...
Do you not have a recent backup of the the solution? I do not believe you can recover just a single table.
