Iteration problem
I have 3 fields that contain Name, phone, fax; each field has 6 iterations. Field 1 is a drop down list to allow selection of name. I am trying to get fields 2 & 3 to follow the drop down list for the correct phone and fax no to the invoice. I have just about tried everything to get it to work. Any ideas? TIA
Hi, it sounds like either your relationships could be incorrect or you may be displaying the wrong fields. Can you please zip and post your solution and I'll take a quick look for you.
