Layout Body records not changing
I have a layout I copied that when you view in browse or preview, the related (detail) records show the same records for every row.
For example, say there are 10 detail rows for the main header row (linked in a relationship). Instead of showing 10 rows, one per detail line, i get 10 rows of the first detail line.
This is killing me but I'm sure it's something simple.
Thanks in advance
Rodd,
It is something simple. You probably have fields from the wrong relationship showing in your portal. Or the portal is based on the wrong relationship, one that is unavailable from the table occurrence that underlies the layout.
Regards
Don
