Self-join two way portal problem
This is probably simple for old hands, but the problem is this - 1 table with 3 fields: Member (repeating text field), Department (text field), and Item (calculation).
Item = if ( Member ≠ ""; Member ; Department ).
Each Department includes multiple members. (separate records)
Each Member belongs to a variety of departments.
I want ONE portal to show:
Members if Item = Department (taking values from a relationship) and ...
Departments if Item = member (taking values from the CURRENT record)
I have no trouble making Members show in the portal when Item = Department with a self-join relationship ... but can't figure out how ALSO to make the Departments show in the portal when Item = Member (WITHOUT entering the names of every Member to each Department record )!
In other words, I want the portal to show related records when Item = Department, BUT to show values from the SAME record when Item = Member)
Any clues welcome.
