Layout Container Problem
I have made several basic databases with containers, they all work great no problems, some are from flat files, some are for related tables etc…just no problems.
Now today, I am working on a layout and I add a container (this is also a flat file db w/just a few fields and 1 container).
I right click in the container to add a photo and !!!Nothing!!!. I think it’s a mouse problem so I install a new mouse…still nothing.
I check all the setting to make sure the container can be accessed and it can be.
I then click on the container again and boom..it works. I close out the db and reopen it, and now it will not work.
I am lost, has anyone ever had this problem with a container? All the other fields work just fine, no problems what so ever, its just the container works one time when you click, and the next it does not.
If I left click on the container (no matter if it is taking a right click or not) it opens up the sound recording window.
Nothing has changed on my PC, I have not downloaded anything new…and I have uninstalled FM8.5a and reinstalled and updated it, but it still works and then it will not, on the container.
James
