February 22, 200818 yr Newbies I am a newbie for FileMaker. When I check for scroll bars in the portal setup dialog they don't show up on the interface. But if click in the corners, the I can scroll down. I just cannot see the scroll bars. Users will not know that there are scroll bars. I am using FileMaekr 8 version 3. Thanks for any help.
February 22, 200818 yr Check your "pen settings"... Make sure that you do not have the pen color the same as your background (i.e. white), that your pen pattern is solid, and that your pen line width is at least hairline.
February 22, 200818 yr Author Newbies Thanks vodka! It worked! My background is blue and pen color is white. Isn't supposed to work? Now, I will check the pen settings whenever I have problems with displaying objects. This is my first visit to the forum and it is great to learn FM.
