March 3, 200818 yr Hi - I'm running a Filemaker Pro server and after I put databases on the server and set them to "Open" I can access them via Instant Web Publishing. But when I attempt to sort any of the data, nothing happens. Any assistance would be greatly appreciated. The web address of the server is http://cfa-fmdb.bu.edu/fmi/iwp
March 4, 200818 yr Author Hi Steven - Thanks for the response. I created a new database to test the sorting, and all fields are text fields and are fully indexed, but I still cannot sort through IWP. If you go to http://cfa-fmdb.bu.edu/fmi/iwp and login with username "help" and password "help" you can see what I mean. I would really appreciate any other suggestions. I'm really stuck. Thanks.
March 4, 200818 yr Author Thank you for looking into it - I found out last night that all I had to do was restart the server and the files worked themselves out. Thanks for the help.
