FileMaker 2026 Released
help with lp command with do shell script
This applescript works great:
tell application "FileMaker Pro Advanced"
set img_URL to cell "zz__web_ImgPath_CertImg__lct" of current record
do shell script "cd /Applications/Cert_Print; curl -m 1 -fO " & img_URL
end tell
set img_path to cell "zz_local_cert_path" of current record
do shell script "lp" & img_path
end tell
Problem I am having is that I would like the image that is downloaded to be fit to the size of the page when printed. I saw the -o option and fitplot but can't seem to make it work. Any ideas or help would be really appreciated.
Drew
You could resize the image, using the sips command.
I found a little more documentation that might help related to fit plot
"This feature depends upon an accurate size in the print file. If no size is given in the file, the page may be scaled incorrectly!"
Great advise Fenton:
Here is the new script
end tell
do shell script "sips --resampleWidth 2250 " & img_path
do shell script "lp -o fitplot " & img_path
end tell
The fitplot is probably not neede at this point but it can't hurt.
Drew
