FM9 SQL problem
I am using FM9 on OSX. I tried adding a record to a sql database from a filemaker file using the "Execute SQL" script step. Though this works and the record gets updated in the external SQL database it gives me a error message every time. The error message I get is:
ODBC Error: [Actual][sql Server] Executing sp_notify_necropsy_results...
The related contents in the log file is:
FileMaker Pro A06E5FA0 EXIT SQLError with return code 0 (SQL_SUCCESS)
SQLHENV 0x1fb70a90
SQLHDBC 0x1fb07c90
SQLHSTMT 0x1fadd170
SQLWCHAR * 0x1fb5ae10
| 01000 |
SQLINTEGER * 0xbffff0f8 (0)
SQLWCHAR * 0x1f38fc00
| [Actual][sql Server] Executing sp_notify |
| _necropsy_results... |
SQLINTEGER 350
SQLSMALLINT * 0xbffff10e (60)
Can anyone please help me find out how to avoid this warning/error. Your help will be highly appreciated.
thanks,
Sudharsan.
Is your SQL Procedure returning you something that you're not handling?
