help me. script help
So I have a list of fields for a score sheet I am using as part of a datasheet in my internship. Each field has 5 boxes which are checked according to never, infrequently, sometimes, fairly often and always. I was wondering how I could assign numbers to these checkboxes (0-4 respectively) and have filemaker add up all the values for a final score.
I'd suggest the following:
1. Create a Value List with the preset values:
Never
Infrequently
Sometimes
Fairly Often
Always
2. Define a text field called 'Freq' and format it as a radio button (not a check box).
3. Define a calculation field to convert 'Freq' to a number:
Case ( Freq = "Never" ; 0 ; Freq = "Infrequently" ; 1 ; Freq = "Sometimes" ; 2; Freq = "Fairly Often"; 3 ; Freq = "Always"; 4)
