Problems using "preview" style parameter
I'm having problem getting the "preview" style parameter to work. My other style parameters appear to work fine. The resulting style when I use the "preview" parameter appears the same as would the default style. My webviewer's calculated URL address is as follows:
"http://pcsfmhost2.srs.gov:8080/SuperContainer/Files/"
& Business_Images::Portal_2_Index
& "?height=" & GetLayoutObjectAttribute( "Business_Image_Thumbnail" ; "height")
& "&width=" & GetLayoutObjectAttribute( "Business_Image_Thumbnail" ; "width" )
& If ( Business_Images::Portal_2_Index = ((Int (( $$original_found_count / 4)) * 4) + 1) ; "&style=nopreview" ; "&style=readonly" )
& "&background-color=rgb(182,182,182)"
Any suggestions?
  • 2 weeks later...
Hi PL,
It looks like you have multiple style parameters. For multiple style parameters, just separate them with a + sign, e.g.
&style=readonly+nopreview+info
  • 2 months later...
Just a follow up... to answer myself :P ... This problem is fixed with SuperContainer v. 2.03.
Hey... thanks! I appreciate the response (Didn't see it before my previous post.)
'Thought you might want to know... what looks like multiple style parameters is a conditional parameter. 'Was pleased to see the flexibility existed and thought it might be of use for you. :P
