Web publishing with FMServer 9 and FM 9 Advanced
I have a single database that I want to share with a colleague. I use FM 9 Advanced to create databases and will soon add FM Server 9 to my Mac OS X Server to share the databases over the local network. As I understand, FM Server 9 doesn't allow you to do instant web publishing.
My question, can I set up the one database to share the one database with FM 9 Advanced and share the rest of the databases to the network with FM Server.
Yes, but it's not going to be optimal for a number of reasons... and it's a bit odd considering you're getting FM Server, which is the correct answer to this question.
Why not get the colleague a copy of FMP and forget the web completely. They can access the file off the FM Server and all will be good.
Maybe I'm wrong but I thought you had to have the FM 9 Server Advanced to publish to the web without PHP. Is that not true?
Not entirely true. You can use XML or XSLT as well.
