March 14, 200125 yr I had reinstalled FM5 (yes, it is a licensed version) on my new computer and everything seems OK. Suddenly I cannot start FM anymore. Would appreciate any advice.
March 14, 200125 yr Can you some more details about your system, and what made you reinstall FM5. Can you also provide any error messages, so that we can understand the problem together more.
March 15, 200125 yr Author quote: Originally posted by BAZ: Can you some more details about your system, and what made you reinstall FM5. Can you also provide any error messages, so that we can understand the problem together more. Basically it is a 800 Mhz computer [new] with plenty of memory 320MB running Windows 2000. I had to install the softwar on the new computer. FM was initially running and just gave up on me. When you now click on the icon the start-up process begins and then stops. Yes, I have tried to reinstall the software - same effect. Regards.
March 15, 200125 yr If you have a Windoes OS, is the icon you are clicking a shortcut on your desktop? It might have become corrupted for some reason or be pointing to an incorrect path. Try trashing the icon and creating a new shortcut from the .exe file.
March 15, 200125 yr quote: Originally posted by miramaya: Basically it is a 800 Mhz computer [new] with plenty of memory 320MB running Windows 2000. I had to install the softwar on the new computer. FM was initially running and just gave up on me. When you now click on the icon the start-up process begins and then stops. Yes, I have tried to reinstall the software - same effect. Regards. I Agree with Alison shortcuts will react to a new install that way try going to your Filemaker app and executing it there if that works create a new shortcut.
March 15, 200125 yr Visit http://www.filemaker.com and download the latest patch form yout copy of FMP. Perhaps the version you have is not compatible with the new OS.
March 16, 200125 yr Author I do not think it is the 'shortcut icon' and FM was working fine before. It must have something to do with access settings but I could not figure this out yet. When you click the application icon FM 'tries' to start, but then stalls on me. Any help?
March 16, 200125 yr Newbies What makes you think it's not the shortcut? Try launching the application itself, without involving the shortcut. If it works, trash the shortcut and create a new one as suggested previously. -Heather
March 16, 200125 yr Author Even when I try to start the application directly it does not work. I have removed all shortcuts. The hour glass starts spinning and stops after about 10 seconds or so and that's it. Regards.
March 20, 200125 yr Author I solved the problem by running "Repair" from the Windows 2000 back-up disk. Something went wrong while I was installing another software package. Many thanks for all advice.
March 28, 200124 yr Newbies I am having the same problem. Can you elaborate on your solutions. thanks very much.
March 28, 200124 yr Newbies never mind... the problem was with a conflict with Yamaha Synth software pre-installed on my dell box.
