Need help on Portal
I had created a file with two layout inside. This two layout are One Delivery Order and One Job Process Record. All this two layout is relationship
with a field can Job No. And at the Job Process Record Layout I create a field call Invoice and with drop down list of COMPLETED, NOT COMPLETED and TO Bill. I also had another field call Billing and been set like below:
Case ( Job No = Delivery Order::Job No: and Invoice = "Not Complete"; "To Bill" ;
Job No = Delivery Order::Job No: and Invoice = "Completed"; "Completed" ;
Job No = Delivery Order PEARSON::Job No and Invoice = "Completed"; "Completed" ;
Job No = Delivery Order PEARSON::Job No ; "To Bill" ;
Job No ≠ Delivery Order::Job No: ; "Not Complete" ;
All this work fine, only problem i have is that i create another layout with portal and a field with drop down list ;) Completed, Not Completed and To bill. I set the relationship with the Job process record layout field: TO Bill.
But they is nothing come out on the portal. Here i try to use the portal method to show only the data on TO Bill or Not Complete
Is anyone can help.
gregory
Welcome to the Forum.
I am having trouble understanding your system. Do you have one table with two layouts or do you have two tables? If you could post your file it would help.
Hi
Happy New Year and thanks for you reply. I will create and post my file for you to take a look.
Hi RalphL
I had created a file with 3 layout. The layout name are:
Job Process Record
Delivery Order and
To Bill Record.
The problem on the To bill Record, which the portal is not working. I try to show all the To Bill field record on the Job Process Record.
gregory
Portal_problem.zip
Your problem is that the field To Bill is an unstored calculation. You can not make a relationship to to an unstored field. If you look at the Relationship Graph you will see a vertical line next to To Bill in the Job Process Record TO. This means that relationship is one way from this TO.
The fix is to change the calculation to a text field and make it auto-entered by calculation allow replacement of existing value.
Hi Ralph:
I am afraid that's not going to work, since the text field will not update when the related "Delivery Order" status changes. I am not quite sure what the purpose here is - maybe it could be solved by a simple find of the jobs to be billed. But if the requirement is to filter a portal to jobs based on the status of their children, then either more relationships are required (the "Ugo method") or some parts must be scripted.
It works in the sample file.
Hi RalphL and Comment
Try and found that the TO Bill field is not change to "To Bill" is still "Not Complete" when they is a Delivery Order create.
The purpose is to Let the account department know that the Job had been Delivery and can start billing.
gregory
How many deliveries can one job have?
Hi Comment
Sometime can more than 10 delivery.
cheers
gregory
So how is this decided and recorded? Your calculation doesn't make much sense, because:
is always true, unless there is no related delivery record. If there is one (or 10, or 100) it will be true - because that's how the relationship is defined.
You need to explain the real situation: what needs to be done for a job to become billable?
Hi Comment
Sorry, no a issue on how many delivery as long as they is one delivery, my account were take note. I have another way to monitor more delivery Order on one Job. I only need to find a way to let the account know that the job had been start delivey and on the Job Process Record, I also have another portal to show on the "not complete" job.
Cheers
gregory
I still don't understand the logic behind your calculation, but this solves the problem of it being unstored, at least.
Portal_problem.fp7.zip
Hi Comment
Thanks for you help. I had try it out and that good for me.
Cheers
gregory
