January 10, 200917 yr I've installed Filemaker Server Advanced 10 on a W2K3 box, running IIS 6. Get the following error during server deployment: Web Server Test Failed Unconfiguring web server... Return Code = 0 Testing Web Server ... Return Code = false Can't seem to find any documentation for this problem. So far, I've tried reinstalling IIS and going back and forth between installs of FMSA 9 and FMSA 10. Very frustrated at Filemaker's offensive scarcity of documentation. Did I really just have a client buy a 50-user license? : Anyone got an idea what I can do next? I'll call FM support on Monday but hoping for a solution before then. Edited January 10, 200917 yr by Guest
January 19, 200917 yr Haven't heard anyone having this problem so it must be machine specific. Are you up-to-date with all the security patches and service packs for that machine? Remember that if you reinstall IIS from the install CD you *must* reapply all service packs and hotfixes.
January 23, 200917 yr Newbies Having the same problem on a Windows server with Server Pro Advanced 9. Installed fine on an XP machine, but when I tried to setup on the 2003 it fails... 8 (
