Filemaker crashing when using "Call Script With Delay"
I'm trying to use the following function in my solution.
int delayMilliseconds = Integer.valueOf( delaySeconds ) * 1000;
new Timer().runAfter( delayMilliseconds,
{fmpro.performScript(fileName,scriptToRun)});
return true;
I'm basically using it to fire a script regularly. So once it fires, it is automatically calls this function again to set it to fire again after X seconds. It works for a while, but then crashes filemaker completely with the error "Runtime Error" and code "R6025 - Pure Virtual Function Call".
When it crashes I get a log file that includes this:
Java Threads: ( => current thread )
=>0x0f18ec00 JavaThread "Timer-32" [_thread_in_native, id=7172, stack(0x196b0000,0x197b0000)]
0x0f18d000 JavaThread "Timer-31" [_thread_blocked, id=8004, stack(0x195b0000,0x196b0000)]
0x0f18c000 JavaThread "Timer-30" [_thread_blocked, id=7168, stack(0x180b0000,0x181b0000)]
0x0f18a800 JavaThread "Timer-29" [_thread_blocked, id=6912, stack(0x194b0000,0x195b0000)]
0x0f188c00 JavaThread "Timer-28" [_thread_blocked, id=6948, stack(0x193b0000,0x194b0000)]
0x0f187c00 JavaThread "Timer-27" [_thread_blocked, id=3108, stack(0x192b0000,0x193b0000)]
0x0f186000 JavaThread "Timer-26" [_thread_blocked, id=7488, stack(0x191b0000,0x192b0000)]
0x0f184800 JavaThread "Timer-25" [_thread_blocked, id=3712, stack(0x190b0000,0x191b0000)]
0x0f182c00 JavaThread "Timer-24" [_thread_blocked, id=7028, stack(0x18fb0000,0x190b0000)]
0x0f176c00 JavaThread "Timer-23" [_thread_blocked, id=6272, stack(0x18eb0000,0x18fb0000)]
0x0f175400 JavaThread "Timer-22" [_thread_blocked, id=5652, stack(0x18db0000,0x18eb0000)]
0x0f170400 JavaThread "Timer-21" [_thread_blocked, id=6944, stack(0x18cb0000,0x18db0000)]
0x0f16e400 JavaThread "Timer-20" [_thread_blocked, id=7276, stack(0x18bb0000,0x18cb0000)]
0x0f16cc00 JavaThread "Timer-19" [_thread_blocked, id=612, stack(0x18ab0000,0x18bb0000)]
0x0f16c800 JavaThread "Timer-18" [_thread_blocked, id=6600, stack(0x189b0000,0x18ab0000)]
0x0f16a000 JavaThread "Timer-17" [_thread_blocked, id=1316, stack(0x188b0000,0x189b0000)]
0x0f165000 JavaThread "Timer-16" [_thread_blocked, id=4296, stack(0x187b0000,0x188b0000)]
0x0f164800 JavaThread "Timer-15" [_thread_blocked, id=7960, stack(0x186b0000,0x187b0000)]
0x0f161c00 JavaThread "Timer-14" [_thread_blocked, id=7048, stack(0x185b0000,0x186b0000)]
0x0f160400 JavaThread "Timer-13" [_thread_blocked, id=7140, stack(0x184b0000,0x185b0000)]
0x0f15d800 JavaThread "Timer-12" [_thread_blocked, id=6760, stack(0x183b0000,0x184b0000)]
0x0f15c400 JavaThread "Timer-11" [_thread_blocked, id=892, stack(0x181b0000,0x182b0000)]
0x0f120c00 JavaThread "Timer-10" [_thread_blocked, id=6720, stack(0x17fb0000,0x180b0000)]
0x0f158c00 JavaThread "Timer-9" [_thread_blocked, id=3180, stack(0x17eb0000,0x17fb0000)]
0x0f157800 JavaThread "Timer-8" [_thread_blocked, id=5660, stack(0x17db0000,0x17eb0000)]
0x0f156000 JavaThread "Timer-7" [_thread_blocked, id=6496, stack(0x17bb0000,0x17cb0000)]
0x0f14e400 JavaThread "Timer-6" [_thread_blocked, id=8144, stack(0x178b0000,0x179b0000)]
0x0f152c00 JavaThread "Timer-5" [_thread_blocked, id=6476, stack(0x17ab0000,0x17bb0000)]
0x0f154800 JavaThread "Timer-4" [_thread_blocked, id=4304, stack(0x179b0000,0x17ab0000)]
0x0ef6c400 JavaThread "Timer-0" [_thread_blocked, id=7928, stack(0x15760000,0x15860000)]
0x0ef95800 JavaThread "Thread-2" daemon [_thread_in_native, id=7356, stack(0x03c50000,0x03d50000)]
0x0ed5dc00 JavaThread "AWT-Windows" daemon [_thread_in_native, id=8016, stack(0x0f750000,0x0f850000)]
0x0ef31000 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=1984, stack(0x0f550000,0x0f650000)]
0x03bd5000 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=4292, stack(0x0eb50000,0x0ec50000)]
0x03bd2400 JavaThread "CompilerThread0" daemon [_thread_blocked, id=5792, stack(0x0ea50000,0x0eb50000)]
0x03bd0c00 JavaThread "Attach Listener" daemon [_thread_blocked, id=4556, stack(0x0e950000,0x0ea50000)]
0x03bcf800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=4288, stack(0x0e850000,0x0e950000)]
0x03bbc800 JavaThread "Finalizer" daemon [_thread_blocked, id=7952, stack(0x0e750000,0x0e850000)]
0x03bbb400 JavaThread "Reference Handler" daemon [_thread_blocked, id=2676, stack(0x0e650000,0x0e750000)]
0x03b3b400 JavaThread "main" [_thread_in_native, id=5052, stack(0x00030000,0x00130000)]
It looks to me like perhaps each timer is staying resident even after it has fired it's script. Could that cause this problem? Anyone got any ideas?
Matt
I've done some more investigating. Instead of using a registered function, I'm using the following code:
EvaluateGroovy( "¶
int delaySeconds = 5;¶
String fileName = "IdleTime";¶
String scriptToRun = "Commit";¶
int delayMilliseconds = delaySeconds * 1000;¶
new Timer().runAfter( delayMilliseconds, {¶
while (true) {¶
fmpro.performScript(fileName, scriptToRun, "1");¶
Thread.currentThread().sleep(delayMilliseconds);¶
return true;¶
Basically I call this once, and it should then call a script once every 5 seconds. It works fine when I am viewing the file that I called this from, but when I have switched to another file, and then switched to use another application it's not long before Filemaker crashes. It is the same in FM8 Advanced and FM8.5 Advanced.
The log file that is produced is as follows:
# An unexpected error has been detected by Java Runtime Environment:
# Internal Error (0xe06d7363), pid=8416, tid=7892
# Java VM: Java HotSpot Client VM (11.0-b15 mixed mode windows-x86)
# Problematic frame:
# C [kernel32.dll+0x12aeb]
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x1022e400): JavaThread "Timer-0" [_thread_in_native, id=7892, stack(0x169b0000,0x16ab0000)]
siginfo: ExceptionCode=0xe06d7363, ExceptionInformation=0x19930520 0x16aae6ac 0x05016b34
Registers:
EAX=0x16aae600, EBX=0x16aae720, ECX=0x00000000, EDX=0x00000000
ESP=0x16aae5fc, EBP=0x16aae650, ESI=0x16aae688, EDI=0x0409bea0
EIP=0x7c812aeb, EFLAGS=0x00000206
Top of Stack: (sp=0x16aae5fc)
0x16aae5fc: 1022e514 e06d7363 00000001 00000000
0x16aae60c: 7c812aeb 00000003 19930520 16aae6ac
0x16aae61c: 05016b34 10223c00 00000001 102243ec
0x16aae62c: 028301d0 00000004 00000004 02830248
0x16aae63c: 028303a8 6d92f44a 01551048 0409bea0
0x16aae64c: 0409bea0 16aae688 0500515e e06d7363
0x16aae65c: 00000001 00000003 16aae67c e06d7363
0x16aae66c: 00000001 00000000 00000000 00000003
Instructions: (pc=0x7c812aeb)
0x7c812adb: 8d 7d c4 f3 a5 5f 8d 45 b0 50 ff 15 10 15 80 7c
0x7c812aeb: 5e c9 c2 10 00 85 ff 0f 8e 36 93 ff ff 8b 55 fc
Stack: [0x169b0000,0x16ab0000], sp=0x16aae5fc, free space=1017k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C 0x0500515e
C 0x04ff7408
j com.prosc.fmkit.types.FMText._createText(Ljava/lang/String;)J+0
j com.prosc.fmkit.types.FMText.(Ljava/lang/String;)V+14
j com.prosc.beanshell.FMPro.performScript(Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;)V+22
v ~StubRoutines::call_stub
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/reflect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+0
j sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+87
j sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+6
j java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+161
j org.codehaus.groovy.reflection.CachedMethod.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+6
j groovy.lang.MetaMethod.doMethodInvoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+9
j groovy.lang.MetaClassImpl.invokeMethod(Ljava/lang/Class;Ljava/lang/Object;Ljava/lang/String;[Ljava/lang/Object;ZZ)Ljava/lang/Object;+1051
j groovy.lang.MetaClassImpl.invokeMethod(Ljava/lang/Object;Ljava/lang/String;[Ljava/lang/Object;)Ljava/lang/Object;+10
j org.codehaus.groovy.runtime.InvokerHelper.invokePojoMethod(Ljava/lang/Object;Ljava/lang/String;Ljava/lang/Object;)Ljava/lang/Object;+24
j org.codehaus.groovy.runtime.InvokerHelper.invokeMethod(Ljava/lang/Object;Ljava/lang/String;Ljava/lang/Object;)Ljava/lang/Object;+55
j org.codehaus.groovy.runtime.ScriptBytecodeAdapter.invokeMethodN(Ljava/lang/Class;Ljava/lang/Object;Ljava/lang/String;[Ljava/lang/Object;)Ljava/lang/Object;+3
j Script1$_run_closure1.doCall(Ljava/lang/Object;)Ljava/lang/Object;+116
j org.codehaus.groovy.runtime.metaclass.ClosureMetaClass.invokeMethod(Ljava/lang/Class;Ljava/lang/Object;Ljava/lang/String;[Ljava/lang/Object;ZZ)Ljava/lang/Object;+240
j org.codehaus.groovy.runtime.ScriptBytecodeAdapter.invokeMethodOnCurrentN(Ljava/lang/Class;Lgroovy/lang/GroovyObject;Ljava/lang/String;[Ljava/lang/Object;)Ljava/lang/Object;+39
j Script1$_run_closure1.doCall()Ljava/lang/Object;+87
j groovy.lang.Closure.call([Ljava/lang/Object;)Ljava/lang/Object;+8
j groovy.lang.Closure.call()Ljava/lang/Object;+6
j org.codehaus.groovy.runtime.DefaultGroovyMethods$3.run()V+4
j java.util.TimerThread.mainLoop()V+221
j java.util.TimerThread.run()V+1
--------------- P R O C E S S ---------------
=>0x1022e400 JavaThread "Timer-0" [_thread_in_native, id=7892, stack(0x169b0000,0x16ab0000)]
0x10145800 JavaThread "Thread-2" daemon [_thread_in_native, id=8364, stack(0x040f0000,0x041f0000)]
0x1007b800 JavaThread "AWT-Windows" daemon [_thread_in_native, id=1568, stack(0x0fba0000,0x0fca0000)]
0x1002d400 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=9180, stack(0x0f9a0000,0x0faa0000)]
0x04087800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=9796, stack(0x0f7a0000,0x0f8a0000)]
0x04081800 JavaThread "CompilerThread0" daemon [_thread_blocked, id=9460, stack(0x0f6a0000,0x0f7a0000)]
0x04080400 JavaThread "Attach Listener" daemon [_thread_blocked, id=9936, stack(0x0f5a0000,0x0f6a0000)]
0x0407f000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=2224, stack(0x0f4a0000,0x0f5a0000)]
0x0406c000 JavaThread "Finalizer" daemon [_thread_blocked, id=9300, stack(0x0f3a0000,0x0f4a0000)]
0x0406ac00 JavaThread "Reference Handler" daemon [_thread_blocked, id=9308, stack(0x0f2a0000,0x0f3a0000)]
0x03feb800 JavaThread "main" [_thread_in_native, id=8564, stack(0x00030000,0x00130000)]
Other Threads:
0x04066000 VMThread [stack: 0x0f1a0000,0x0f2a0000] [id=2476]
0x04091c00 WatcherThread [stack: 0x0f8a0000,0x0f9a0000] [id=7748]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 960K, used 525K [0x07100000, 0x07200000, 0x075e0000)
eden space 896K, 51% used [0x07100000, 0x071737e8, 0x071e0000)
from space 64K, 100% used [0x071e0000, 0x071f0000, 0x071f0000)
to space 64K, 0% used [0x071f0000, 0x071f0000, 0x07200000)
tenured generation total 3072K, used 2438K [0x075e0000, 0x078e0000, 0x0b100000)
the space 3072K, 79% used [0x075e0000, 0x07841a30, 0x07841c00, 0x078e0000)
compacting perm gen total 12288K, used 9045K [0x0b100000, 0x0bd00000, 0x0f100000)
the space 12288K, 73% used [0x0b100000, 0x0b9d54f0, 0x0b9d5600, 0x0bd00000)
No shared spaces configured.
Dynamic libraries:
0x00400000 - 0x008a7000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedFileMaker Pro Advanced.exe
0x7c900000 - 0x7c9af000 C:WINDOWSsystem32ntdll.dll
0x7c800000 - 0x7c8f6000 C:WINDOWSsystem32kernel32.dll
0x4ec50000 - 0x4edf6000 C:WINDOWSWinSxSx86_Microsoft.Windows.GdiPlus_6595b64144ccf1df_1.0.2600.5581_x-ww_dfbc4fc4gdiplus.dll
0x77dd0000 - 0x77e6b000 C:WINDOWSsystem32ADVAPI32.dll
0x77e70000 - 0x77f02000 C:WINDOWSsystem32RPCRT4.dll
0x77fe0000 - 0x77ff1000 C:WINDOWSsystem32Secur32.dll
0x77f10000 - 0x77f59000 C:WINDOWSsystem32GDI32.dll
0x7e410000 - 0x7e4a1000 C:WINDOWSsystem32USER32.dll
0x774e0000 - 0x7761d000 C:WINDOWSsystem32ole32.dll
0x77c10000 - 0x77c68000 C:WINDOWSsystem32msvcrt.dll
0x5d090000 - 0x5d12a000 C:WINDOWSsystem32COMCTL32.dll
0x76eb0000 - 0x76edf000 C:WINDOWSsystem32TAPI32.dll
0x76e80000 - 0x76e8e000 C:WINDOWSsystem32rtutils.dll
0x77f60000 - 0x77fd6000 C:WINDOWSsystem32SHLWAPI.dll
0x76b40000 - 0x76b6d000 C:WINDOWSsystem32WINMM.dll
0x10000000 - 0x1000d000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedXalanDOM.dll
0x7c3a0000 - 0x7c41b000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedMSVCP71.dll
0x7c340000 - 0x7c396000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedMSVCR71.dll
0x76390000 - 0x763ad000 C:WINDOWSsystem32IMM32.dll
0x74320000 - 0x7435d000 C:WINDOWSsystem32ODBC32.dll
0x763b0000 - 0x763f9000 C:WINDOWSsystem32comdlg32.dll
0x7c9c0000 - 0x7d1d7000 C:WINDOWSsystem32SHELL32.dll
0x76f60000 - 0x76f8c000 C:WINDOWSsystem32WLDAP32.dll
0x12000000 - 0x12153000 C:Program FilesFileMakerFileMaker Pro 8 Advancedxerces.dll
0x71ab0000 - 0x71ac7000 C:WINDOWSsystem32WS2_32.dll
0x71aa0000 - 0x71aa8000 C:WINDOWSsystem32WS2HELP.dll
0x00340000 - 0x003dc000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedXSLT.dll
0x009b0000 - 0x00a08000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedXPath.dll
0x003e0000 - 0x003ed000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedDOMSupport.dll
0x00a10000 - 0x00a44000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedPlatformSupport.dll
0x00a50000 - 0x00a6f000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedXMLSupport.dll
0x00a70000 - 0x00a91000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedXalanSourceTree.dll
0x00aa0000 - 0x00ace000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedXercesParserLiaison.dll
0x00ad0000 - 0x00ae7000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedXalanTransformer.dll
0x003f0000 - 0x003fa000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedXalanExtensions.dll
0x00af0000 - 0x00e7e000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedDL61PDFL.dll
0x00e80000 - 0x00f15000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedDL61XMP.dll
0x00f20000 - 0x00f93000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedDL61JP2K.dll
0x00fa0000 - 0x00fc6000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedDL61BIB.dll
0x00fd0000 - 0x01005000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedDL61BIBUtils.dll
0x01010000 - 0x0109f000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedDL61ACE.dll
0x010a0000 - 0x01238000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedDL61AGM.dll
0x01240000 - 0x0126d000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedDL61ARE.dll
0x01270000 - 0x01436000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedDL61CoolType.dll
0x71b20000 - 0x71b32000 C:WINDOWSsystem32MPR.dll
0x73000000 - 0x73026000 C:WINDOWSsystem32WINSPOOL.DRV
0x01440000 - 0x0150a000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedDli_dll.dll
0x4a800000 - 0x4a88f000 C:Program FilesFileMakerFileMaker Pro 8 Advancedicuuc26.dll
0x4ad00000 - 0x4b4ed000 C:Program FilesFileMakerFileMaker Pro 8 Advancedicudt26l.dll
0x01510000 - 0x01646000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedSupport.dll
0x5b860000 - 0x5b8b5000 C:WINDOWSsystem32NETAPI32.dll
0x01650000 - 0x01722000 C:Program FilesFileMakerFileMaker Pro 8 Advancedlibeay32.dll
0x71ad0000 - 0x71ad9000 C:WINDOWSsystem32WSOCK32.dll
0x59a60000 - 0x59b01000 C:WINDOWSsystem32dbghelp.dll
0x77c00000 - 0x77c08000 C:WINDOWSsystem32VERSION.dll
0x76bf0000 - 0x76bfb000 C:WINDOWSsystem32PSAPI.DLL
0x01730000 - 0x017b2000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedPROOFREADER.dll
0x017c0000 - 0x017f5000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedXGrfx.dll
0x01800000 - 0x0181a000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedXCore.dll
0x01820000 - 0x0188f000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedHBAM.dll
0x01890000 - 0x01898000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedOmniThread.dll
0x018a0000 - 0x01994000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedOmniORB4.dll
0x019a0000 - 0x019c7000 C:Program FilesFileMakerFileMaker Pro 8 Advancedssleay32.dll
0x019d0000 - 0x01afe000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedOmniDynamic4.dll
0x76d60000 - 0x76d79000 C:WINDOWSsystem32iphlpapi.dll
0x01b00000 - 0x01d2a000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedDBEngine.dll
0x01d30000 - 0x01e32000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedMFC71U.DLL
0x77120000 - 0x771ab000 C:WINDOWSsystem32OLEAUT32.dll
0x01e40000 - 0x01e60000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedFMOLE.dll
0x7df70000 - 0x7df92000 C:WINDOWSsystem32oledlg.dll
0x01e60000 - 0x01ebc000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedDBConverter.dll
0x01ec0000 - 0x01f28000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedFMScript.dll
0x01f30000 - 0x01f6b000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedFMLayout.dll
0x01f70000 - 0x01fd0000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedFMUserModel.dll
0x01fd0000 - 0x02084000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedXMLEngine.dll
0x02090000 - 0x020ef000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedXText.dll
0x020f0000 - 0x02172000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedXFC.dll
0x02180000 - 0x0218d000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedNSViews.dll
0x02190000 - 0x021ac000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedMFCX.dll
0x021b0000 - 0x02230000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedXDraw.dll
0x76380000 - 0x76385000 C:WINDOWSsystem32MSIMG32.dll
0x629c0000 - 0x629c9000 C:WINDOWSsystem32LPK.DLL
0x74d90000 - 0x74dfb000 C:WINDOWSsystem32USP10.dll
0x02740000 - 0x02745000 C:WINDOWSsystem32avgrsstx.dll
0x773d0000 - 0x774d3000 C:WINDOWSWinSxSx86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83comctl32.dll
0x029a0000 - 0x029b7000 C:WINDOWSsystem32odbcint.dll
0x5d360000 - 0x5d36e000 C:WINDOWSsystem32MFC71ENU.DLL
0x02cb0000 - 0x02cc6000 C:Program FilesCommon FilesLogitechLVMVFMLVPrcInj.dll
0x5ad70000 - 0x5ada8000 C:WINDOWSsystem32uxtheme.dll
0x74720000 - 0x7476c000 C:WINDOWSsystem32MSCTF.dll
0x00940000 - 0x0094a000 C:WINDOWSsystem32MSNCHATHOOK.DLL
0x00950000 - 0x0097d000 C:WINDOWSsystem32sysenv.dll
0x74c80000 - 0x74cac000 C:WINDOWSsystem32OLEACC.dll
0x76080000 - 0x760e5000 C:WINDOWSsystem32MSVCP60.dll
0x02ce0000 - 0x02d4c000 C:WINDOWSsystem32CryptoAPI.dll
0x009a0000 - 0x009a8000 C:Program FilesSizersizer.dll
0x76fd0000 - 0x7704f000 C:WINDOWSsystem32CLBCATQ.DLL
0x77050000 - 0x77115000 C:WINDOWSsystem32COMRes.dll
0x75cf0000 - 0x75d81000 C:WINDOWSsystem32mlang.dll
0x03090000 - 0x03ae8000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedExtensionsEnglishFMRsrc.DLL
0x755c0000 - 0x755ee000 C:WINDOWSsystem32msctfime.ime
0x72d20000 - 0x72d29000 C:WINDOWSsystem32wdmaud.drv
0x76c30000 - 0x76c5e000 C:WINDOWSsystem32WINTRUST.dll
0x77a80000 - 0x77b15000 C:WINDOWSsystem32CRYPT32.dll
0x77b20000 - 0x77b32000 C:WINDOWSsystem32MSASN1.dll
0x76c90000 - 0x76cb8000 C:WINDOWSsystem32IMAGEHLP.dll
0x72d10000 - 0x72d18000 C:WINDOWSsystem32msacm32.drv
0x77be0000 - 0x77bf5000 C:WINDOWSsystem32MSACM32.dll
0x77bd0000 - 0x77bd7000 C:WINDOWSsystem32midimap.dll
0x03050000 - 0x03059000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedExtensionsWeb SupportResourcesfmlangEnglish.dll
0x03020000 - 0x03031000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedEXTENSIONSFMSAUC.fmx
0x20000000 - 0x2002f000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedEXTENSIONSactivatr.fmx
0x046f0000 - 0x04718000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedEXTENSIONSPopTime_Win.fmx
0x04820000 - 0x048ff000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedEXTENSIONSScriptFire.fmx
0x04900000 - 0x0491b000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedFMWrapper.dll
0x04930000 - 0x04ab3000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedEXTENSIONSmail.it.fmx
0x71a50000 - 0x71a8f000 C:WINDOWSSystem32mswsock.dll
0x76f20000 - 0x76f47000 C:WINDOWSsystem32DNSAPI.dll
0x76fb0000 - 0x76fb8000 C:WINDOWSSystem32winrnr.dll
0x16080000 - 0x160a5000 C:Program FilesBonjourmdnsNSP.dll
0x751d0000 - 0x751ee000 C:WINDOWSsystem32wshbth.dll
0x77920000 - 0x77a13000 C:WINDOWSsystem32SETUPAPI.dll
0x76fc0000 - 0x76fc6000 C:WINDOWSsystem32rasadhlp.dll
0x04b40000 - 0x04c80000 C:Program FilesFileMakerFileMaker Pro 8 AdvancedEXTENSIONSmyFMbutler_PrinterSwitch.fmx
0x6a900000 - 0x6a9cb000 C:WINDOWSSystem32spoolDRIVERSW32X863BRUMF04B.DLL
0x742e0000 - 0x742f5000 C:WINDOWSsystem32SPOOLSS.DLL
0x04ca0000 - 0x04cb1000 C:WINDOWSSystem32spoolDRIVERSW32X863BRLMF04B.DLL
VM Arguments:
jvm_args: -Xms4m -Xmx64m -Djava.util.logging.config.file=C:Templogging.properties vfprintf -Xbootclasspath/a:C:Program FilesJavajre6libdeploy.jar;C:Program FilesJavajre6libplugin.jar;C:Program FilesJavajre6libjavaws.jar -Djava.ext.dirs=C:Program FilesJavajre6libext;C:Program FilesJavajre6lib;C:Program FilesJavajre6libdeploy;C:WINDOWSSunJavalibext;
java_command:
Launcher Type: generic
Environment Variables:
CLASSPATH=.;C:Program FilesJavajre1.6.0_02libextQTJava.zip
PATH=C:Program FilesFileMakerFileMaker Pro 8.5 Advanced;C:Program FilesMail EnableBIN;C:Perlbin;C:WINDOWSsystem32;C:WINDOWS;C:WINDOWSSystem32Wbem;C:Program FilesATI TechnologiesATI.ACE;C:Program FilesIntelWirelessBin;C:Program FilesCommon FilesGTK2.0bin;C:Program FilesCommon FilesTeleca Shared;C:Program FilesQuickTimeQTSystem;C:PROGRA~1BorlandDelphi6Bin;C:PROGRA~1BorlandDelphi6ProjectsBpl;C:PROGRA~1NCFTP;C:Program FilesMicrosoft Visual StudioCommonToolsWinNT;C:Program FilesMicrosoft Visual StudioCommonMSDev98Bin;C:Program FilesMicrosoft Visual StudioCommonTools;C:Program FilesMicrosoft Visual StudioVC98bin;C:Program FilesEvolvITOrgITFileSync;C:Program FilesEvolvITOrgITFileSync;C:BorlandBCC55Bin;C:Program FilesEvolvITDocGen;;C:PROGRA~1COMMON~1MUVEET~1030625;C:Program FilesJavajre6bin;C:Program FilesJavajre6binclient
USERNAME=matt
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 6 Model 15 Stepping 6, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows XP Build 2600 Service Pack 3
CPU:total 2 (2 cores per cpu, 1 threads per core) family 6 model 15 stepping 6, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3
Memory: 4k page, physical 2097151k(1491580k free), swap 4194303k(3420864k free)
vm_info: Java HotSpot Client VM (11.0-b15) for windows-x86 JRE (1.6.0_10-rc-b28), built on Jul 21 2008 00:52:03 by "java_re" with MS VC++ 7.1
time: Fri Jan 16 15:08:58 2009
elapsed time: 65 seconds
Any help would be appreciated.
working on reproducing this issue...
  • 1 month later...
Did anything come of this investigation?
