Sort Problem
Hello Community at large,
I have a problem that has frustrated me for days now.
Chief Complaint: I can not figure out how to sort by day of the month only (within dates covering only one month)
Details: We have a Demographics type data base and I need to be able to make lists of everyone with dates in the upcoming month (there are actually four date fields I have to search through).
I currently run a search like 2/{1..31}/* to find all dates that fall within the month, and then view them all in a layout I created for this purpose. But the results need to then be organized by the day of the month. The problem I have run into so far is that FMP seems to follow the logical globally accepted rule that the year is actually important to chronology. I know it can be done, but how?
Same month, but not the same year? You will need to add a calculation field (result is Number) =
Day ( YourDateField )
and use it for sorting.
You are a great person, thank you!
I am new to fmp so I am figuring this out as I go. That looks simple enough that I should of known how to do it, but I would of torn my hair out trying to solve it on my own.
