February 14, 200917 yr Hello Any help on this would be greatly appreciated I am sure it is something simple but I cant get it. Basically I have 2 tables, clients and jobs with a relationship set up between id codes which makes a job specific to a client. The problem I am trying to solve is that I want a portal on the jobs table which shows all of the clients listed I just cant work out how to setup the relationship. I want to use this method rather than a dropdown list because I want to be able to have more freedom over formatting. Thanks again James
February 14, 200917 yr Hi when in the relationship graph, go to change the symbol = with the symbol X inside the line that units the IDjobs
February 14, 200917 yr Author THanks, that works perfectly,I never would have tried that. Thanks again James
