container fields and a huge brick wall...
hey all, I'm having trouble figuring out why my populated container field wont display properly.
I was cruising thru a calendar tutorial the second time around and im stuck in the same spot.
I've created a container field, populated it, and then created a TO just as the tutorial specified but each time I have done this I havent been able to see the square that is in the container field by going to the field in the TO. I did notice that I was doing a fmpro9 advanced tutorial while using fmpro9. There shouldnt be a difference there if im simply creating container fields, right?
Have i missed something really simple or do I need to "turn something on"?
I am pretty confused...
