Radio button problem
I searched the values list forum, but could not find this problem mentioned...
I have a simple custom value list with 2 items:
Process Now
Schedule for Future
When I select Radio Button to display the list, it truncates the values. I tried different fonts and font sizes and even reversed the order. I tried a horizontal and vertical display and made sure the field is large enough to fit the full value.
If I add several spaces to the end of each value, it will display the values. If I add 1 space to the end of each, then it displays
Process
Schedule
I am running on MAC, FMP 10.
Anyone have this problem??
Hi Ellen
can you post an example file ?
The problem seems to happen only if the field is in uppercase.
See attached.
TestRadioButton.fp7.zip
Yes, only with Upper case.
I suggest to enter the values in Upper case and format the field the way you need.
( or find a font that doesn't have such behavior )
TestRadioButton.zip
Interesting bug. It seems to be OK if you select a monospaced font.
I just went with using proper case. Good to know this is an actual bug!!
