DDR and Snow Leopard Problems
I am trying to create a DDR in FileMaker 10 in Snow Leopard and I get a blank Summary.xml. When I try to get into the DDR, it shows the syntax but never loads the form. I have another mac with Leopard on it and it works just fine. On the web I see a number of users having problems with Filemaker on Snow Leopard.
Is this common?
Update: This was not the fault of Snow Leopard. It was the file itself.
