Multilanguage and evaluate Problem
I'm using the mutlilanguage solution found in the filmaker 10 Bible.
I have a table "I" with calculation fields.
For example the field Country contains following calculation:
Evaluate("LanguageResources::Country"; gLanguageID)
Now you can imagine that it is a big work to change this calculation for every field (every Label, tooltip, dialog message, etc has a field about 200 in my solution)
I tried to get the Name of the field and to use it for the evaluate function like this:
Evaluate("LanguageResources::GetFieldName(self)"; gLanguageID)
But GetFieldName returns I::Country
(I is a table that contains the same fields like LanguageResources)
So I tried to substitute the "I::" with
Substitute(GetFieldName(self);"I";3;"")
This works fine but I cannot put together the two functions:
Evaluate("LanguageResources::Substitute(....)";gLanguageID);
So any ideas how to get work this? Or do I really have to change by hand the Fieldname in the calculation
by
ChiSao
