Searching radio button sets ambiguity problem
Hi all. I have a simple radio button set with two values, "Confirmed" and "Not confirmed", without the quotes. When I search by "Not confirmed" the results are as expected. However searching by "Confirmed" produces the results for both of those values, obviously Filemaker thinks it's not a literal search and just tries to find a match somewhere in the field which is not what I want. Short of changing those values to different things is there anything one could to to alter the search behavior for this specific case?
However searching by "Confirmed" ...
search for: "==Confirmed" ( w/o quotes )
Daniele, thanks, but I wanted to know if that was possible to do when searching using radio button fields, not a text field.
If the field is never empty, you can search for "Not confirmed" and omitt them
