Kiosks and Plugins Problem
I created a Kiosk using FM5 under Windows. The kiosk version seems to have eliminated the two plugins I was using (Troi Dialogs and PCC Calendar). They were both working in the FM5 version, but not in the kiosk. Anybody have any ideas? Thanks.
  • 5 months later...
I know your question is fairly old, but since you have received no replies I decided to respond.
I also use the Kioske mode and Troi Dialog plug-in. In order to make the Troi Dialog plug-in work in the Kioske app, you need to create a System sub-folder in the Kioske folder and then copy the Trio Dialog plug-in to that folder. This seems to be the same techinue for all other plug-ins I have tried so far. Hope this is helpful...
[ April 22, 2001: Message edited by: Jack Farrell ]
Thanks, but I solved that issue a long time ago (doing exactly what you said).
Steve,
Here is what I have done to solve the same problem. After creating the System folder, I found it necessary to Re-Unzip the Plug-Ins from the their original Zip files, into the System folder. Merely copying them from another folder seems, for reasons unknown, not to work
Give it a try. It worked for me.
Gary
