Relationship using calculated and looked up values
Hi
I would like to build a relationship to populate a portal where.
Customer Invoice
Cust_pk = cust_fk
g_zero < amount outstanding
where g_zero is a global = 0
I cant use a calculation in the relationship because I get the amount ourstanding from another table.
Invoice Allocations
invoice_pk = invoice_fk
amt_outstanding =
invoice total - sum(allocations::invoice total)
I can make this work by doing the calculation and setting a separate field with fixed results (either the amount outstanding or a calculated cust_key.
I am thinking there must be a more elegant way to solve this display of part paid or unpaid invoices in a portal.
John
