February 15, 201016 yr I have 1 client who has a problem with the Insert command (on Insert picture or Insert file.) The Insert functions are scripted and set to Insert with Reference only. When he tries to run any of the Insert scripts, his program immediately shuts down. My program is an FM10 runtime application. He is running on Vista Ultimate with Service Pack 2, 32bit. I have over 500 clients running my application, in various OS (both MAC & PC) and he is the only one that seems to be having this problem (at least that I know of.) Has anyone encountered a similar problem or have any idea as to cause or how to fix it?? Thanks.
February 23, 201016 yr Hi, My clients right click on image... will it work that way with you client?? >>>>The Insert functions are scripted and set to Insert with Reference only. I like to do a scripted situation like you describe.. still trying to figure out FM... would you share your script .. how to set reference an image... that I can learn from [email protected]
