March 11, 201016 yr I'm not sure how to create this. I have 3 fields from the same table on a layout - 2 drop downs (A & :& one edit box ©. Also involved but not shown is another field from the same table (D). The user will select A & B , fill in C, then click a button. I want the button to find records that include the data from the two drop downs(A & B ) then take the data from the edit box© and put it into field D of those records. Any ideas? Thanks in advance.
