I need help with XSL Style Sheet
Hi
I'm new to XML and I need some help with xsl style sheets. I have an xml file that is generated from our webpage that I need to import to filemaker.
I don't understand how to make an xsl style sheet for this file. Can someone please help med?
Johan
<?xml version="1.0" encoding="UTF-8"?>
Bas-Elbas-Epiphone
Thunderbird Goth
118151
00000000003245.0000
Try the attached.
Note however that the source you have posted is NOT a valid XML document: there's no closing tag for the element. If that's how the original file looks, you won't be able to import it.
products.zip
Thank you so much!!
I accidentally deleted the closing tag. It works perfect.
Johan
  • 1 month later...
I too trying to make a xsl style sheets so I can import an XML from an http request. I have no ideal how to do this. Is there an easy to understand guide Anybody can get me started in the right direction. This is what I need to convert.
<?xml version="1.0" encoding="UTF-8" ?>
2010-06-15 19:37:28
2010-06-15 19:39:32
This might be a good starting point:
http://my.advisor.com/doc/12009
