Reset container reference path
How do you reset the path to a file referenced in a container field? If a file is moved, or duplicated for client machines of a hosted solution, how do you make the solution file locate the referenced container file.?
Basically, you calc the new path.
This thread should help:
http://fmforums.com/forum/showtopic.php?tid/192235/post/276677/hl/update+path/fromsearch/1/#276677
  • 3 months later...
So as not to leave things hanging, attached is the solution if anyone is interested. Thanks are due to FM's tech support. The problem was solved with two scripts. One to mount the image folder consistently across client machines, the other to set the image file refs for host and clients.
shared_container_fields.zip
