September 7, 201015 yr Newbies Hi Forum-Members -) I have a task-DB, in which I want to sort the tasks after the Deadlines automatically. So I have the tasks sorted after the "priority". There is only one problem: If the field Deadline is empty, these tasks are sorted to the beginning! (Maximum of priority!) But if I finished a task, i clear the deadline... that's only one reason for not all of the tasks having deadlines. By the way, it's a pain to write a script for searching and sorting combined. Any help is more than appreciated! Hopefully my English is not tooo bad to understand :-) Michael7419 Edited September 7, 201015 yr by Guest
September 7, 201015 yr It would help knowing what do you actually want to happen: show the tasks with no deadline at the end, or not show them at all.
September 7, 201015 yr Author Newbies It would help knowing what do you actually want to happen: show the tasks with no deadline at the end, or not show them at all. I like to not show tasks with no deadline at all, but sorted after date... Thanks for your thoughts! Michael
September 7, 201015 yr :idunno: If you don't want to show tasks without a deadline, then what does it matter how they are sorted? You can only sort records in the found set.
