Need help with SCSetContainer
I need help with SCSetContainer. I'm bit confused by the \ and /'s being backwards from windows and when to filewin:
Should the following work to add a file to supercontainer. $result is resolving to "ERROR"
Set Variable[$result;Value:SCSetContainer("Docuaments\175";"c:\test.txt")]
Scott
What is the error message you receive when SCSetContainer returns "ERROR"? You can call SCLastError after a function returns error to get the details of why the function returned an error.
