Help With Contracts Solution
I've run into a brick wall while trying to develop my solution. I'm making a simple contracting managment system with couple of tables "contracts", "contract_articles" and "contracts_lines" similar to regular product/invoicing system.
However there is one special feature I want when creating new contracts: I want to automatically insert client and price data (from external table) into contract articles where appropriate. For example I would select "Price and payment" article from contract_articles table and insert price into article text. First I thought I would be able to use some sort of variable inside article text which would be then replaced with proper data. But I guess this is not possible.
Do you guys have some advice on how I should handle this problem?
Thanks in advance!
I'm not quite sure if I understand your question, but if I do then this might help...
http://www.briandunning.com/cf/831
Thanks! This looks to be exactly what I need. Now what would be the best way to perform this function on my text? I imagine I could run it with script triggers or maybe when I generate contract for printing?
I don't know what will work best for your database, but here are a few ways to perform it:
- custom menu: perform script on New Record
- script triggers
- button on layout
- have a separate calculated field
Great! I'll try with script triggers first and see if that works alright.
Thanks again!
