Need Help With Drop Down Menu In 8.5
Phrase
For best selection See a store near you
Phrase Export
Phrase Export French
Visitez nos magazins pour la gemme
Displayed as "Drop Down List"
Values from " Undercopy drop down Value List
Using Values from "Phrase"
When i use it, I select the Phrase- and the Phrase Export Displays in the drop down menu for selection.
I have the "Phrase Export French in the Table, but I cannot make it display on the page properly for french. I wanted to link these together so that when the English was changed the french would be automatically changed as well.
Any help you could provide wouuld be greatly appreciated. I am using FileMaker Pro 8.5
Not quite sure what you're after. Perhaps something like this?
http://fmforums.com/forum/topic/68607-multiple-language-fields/page__p__343273#entry325270
