Need Developer to Help Integrate Quickbooks with Filemaker
Several years ago I created a FM solution for a screenprinting company which they have been using and modifying ever since. Currently they would like to integrate it with their Quickbooks, but are not having any luck getting all the information to transfer correctly. They have been demoing a plug in (not sure which one right now) and are not having good luck.
They would like to speak to someone that could take a look at their system and create a solution to integrate the two. This is not something that I can do and have told them I would pass along suggestions.
I believe they are using FM 8 or 8.5.
If any of you could pass along some contact information, I will pass it along to them so they can work directly with a developer to help them with this problem.
Thanks!
Those interested, just PM Jill.
btw, the plugin that I had success with was Productive Computing's Outlook Manipulator.
