Print Current record Problem
I have a form that I want to only print the current record.
On Mac, LaserWriter 8 (8.7.1) I have checked Print: "Current Record"
in the print dialog, hit "save settings" and everything prints
correctly, but the next time I open up the database and print this same
form my print settings default to printing all of my records
and my page orientation gets changed.
Has anyone gotta a fix or solution?
Any help is appreciated...
You need to create printing script which includes the script steps:
Page Setup (restore)
Print ()
The Page Setup step "remembers" what the setting was when the script was created. With this step in a script, you will get a dialog every time you close the script in Scriptmaker asking if you want to keep or replace the current print settings.
-bd
