Help with Script
Hi All,
I am very new to FM. I am running FM 11 Adv
I have a field on my page that is a radio button(paid_yes_no) that is defaulted data to NO.
I have created a script that, when attached to a button in another database does the following.
Open File["Invoice"]
Go to Field [invoice::paid_yes_no]
NOT SURE WHAT TO DO NEXT
It is defaulted as NO and I need it to change the value in the field to Yes. (It is a radio button)
MG
If you want to change the field from no to yes, just include the following in your script
Set Field(Invoice::paid;"yes")
Note: If you are already in the correct record, you do not need the Go to Field step in your script.
Regards,
Sdig.
Regards,
Sdig.
Hi Sdig,
Thanks for your time but when I use Set field in the script it only gives me the option of choosing the field I cannot use a semicolon or anything else. If I swith it to a calculation then it does not see set field as a parameter.
Maybe I am not following you correctly.
Thanks..MG
