"How i create connection with FileMaker pro 5"
Hi there,
i m working with FileMaker pro 5 on mac.
For automation of database, i want to create connection with FM pro 5 database file.
is there ODBC provide for FileMaker pro 5?
how would this will possible on mac.
pls help me about this.
Regards:
Coolbdy
Yes ODBC was around at least for FMP 6 (which is compatible with 5.0 and 5.5). However on a Mac today it would be highly likely that the drivers won't be compatible with the current OS. My advice would be to convert to FMP 11 and do it in the newer version.
Is There any SDK available for lower version of FileMaker pro 5 and 6 on mac for automation.
i want to create connection with .fp5 file database.
and get work on .fp5 database file.(Eg: create table and columns(with supported data types),apply primary key, apply field properties,and apply other features of FileMaker).
Is this to support a legacy system, or as a learning exercise?
If it's a learning exercise: why learn on a version that is now several years old and essentially obsolete?
