Script Problem
I have a script that is designed to either print or export an excel file with information. If I select print it works, but export, goes through the motions and doesn't save the file. I can't figure out what the issue is. If anyone can look at the jpeg and tell me where I went wrong, I would appreciate it.
Dave
Sorry, here it is
post-71360-0-56045700-1321577405_thumb.p
If you're using "No dialog" in Save Records As Excel I think you've got to "Specify output file..."
Thanks Crazy Eye,
I fixed that now, but there is still something wrong with the script from that point forward. The script will continue on and do nothing. It does not end up saving the file or following through. So somewhere in my script after that point things are messed up.
Dave
Figured it out, thanks for the help.
I haven't used this in awhile and since Lion does not support Rosseta, you have to save the export in xlsx format. That is why nothing happened but the script didn't fail.
